Of alles ook naar Europa komt is nog maar de vraag maar dit zijn de nieuwe en verbeterde producten van Meguiar's voor 2012:
ConsumentenlijnPerfect Clarity Glass Cleaner
•Professional grade glass cleaner
•Can be used in the sun
•Glass stays cleaner longer with dust repellent technology
•Leaves behind streak-free "Perfect Clarity" glass - Clarity you can see!
•Unique chemistry contains lubricants that create an easy slide effect with no residue
Nieuwe glasreiniger, gaat waarschijnlijk de NXT Glass Cleaner op termijn vervangen.
Ultimate Wash & Wax Anywhere
Product attributes:
•Safely cleans more "dirt" than a spray detailer, AND leaves hydrophobic wax protection!
•1 bottle will do 3 - 5 average cars
•The solution to "I want to wash my car, but..."
•"I don't have access to a hose."
•"it's winter.:
•"my city is under water restrictions."
•"I live in an apartment."
•This is the solution for consumers who don't have the space to do a traditional wash, as well as enthusiasts who need something more than a detailer
Hot Rims Brake Dust Barrier
Product attributes:
•Truly lasts on wheels
•Works on painted, chrome and polished aluminum wheels
•Makes wheels easier to clean
•Outperforms existing wheel protectants
Rubbing & Polishing Compound
(nieuwe verpakking, is nu in blikvorm)
Product attributes:
•Rubbing compound: Removes heavy oxidation
•Polishing compound: Removes light swirls & adds gloss ("clarity"
•Clear coat safe
•Non-scratching
•Same formula as tubs, which are being discontinued
Gold Class Premium Quik Detailer
Product attributes:
•It's all about the gloss!
•Delivers a dark, super glossy finish
•Makes black cars blacker!
•Delivers same cleaning ability as our other detailers
Gold Class Carnauba Plus Quik Wax
Product attributes:
•Delivers a deep, rich, more traditional wax finish
•Tactile evidence of the “wax” protection that’s left behind
•Non-whitening on trim
•Can be applied in full sun
Quik Wax: New & Improved Formula
Product attributes:
•New formula leapfrogs competitive products
•True "wax-as-you-dry" formula
•Instant gratification: Great looking results!
Hot Rims All Wheel & Tire Cleaner
New & Improved
Product attributes:
•Reformulated to clean wheels and tires
•Safe on all factory coated wheels
•Visually see dirt leaving the wheel & tire
•Increased foaming action
***geen plaatje***
Product Attributes:
•Helps maintain headlight clarity for new & recently restored headlights
•Provides durable protection from harmful and damaging UV rays
Headlight Protectant
DynaCone Pad Cleaner
Product attributes:
•Safe on the DynaCone and other metal polishing pads
•Fast-acting surfactants dissolves away metal polishing grime
•Replenishment for the cleaner in the Wheel Polishing Kit
***geen plaatje***
Meguiar's PowerSystem
Product attributes:
•Utilize this conventional, non-threatening tool to power a proprietary, patented, dual-action attachment
•More than a wax applicator - Provides a platform for multi-function applications
•More than a polisher - A platform that allows tremendous versatility serving multiple applications
•Using any corded drill, the forced rotation movement allows for safe and effective defect correction
Opzetstuk voor boormachines met Dual Action functie!
Detailerlijn:L
eather Cleaner
Product attributes:
–Removes tough stains
–Non-staining formula quickly cleans leather
–Restores “like new” look
–Colorless with a pleasant citrus fragrance
–Less aggressive than APC
–RTU
–More thorough cleaning that D180
***geen plaatje***
Synthetic X Press Liquid Wax
Product attributes:
•Wipe on & off
•Long lasting hydrophobic protection
•Deep Dark Wet Shine
•No dusting
•Can be applied to wet or dry car
•Hand/DA application
Rinse Free Express Wash
Product attributes:
•Exterior / Interior Wash -128:1 (1 ounce / gallon)
•Cleans all vehicle surfaces
•Non-scratch, non-streaking formula
•Paintable / contains no silicones
•Biodegradable
***geen plaatje***
Tire & Trim Gel
Product attributes:
•Provides deep satin black look
•Thick consistency, no runs or drips
•Non-streaking formula
•VOC Compliant
•No oily residue left behind (Dries dry to the touch)
***geen plaatje***
Marine lijn:Teak Cleaner
Product attributes:
•Quikly cleans and brightens teak
•Spray on, brush & hose off
•Biodegradable
Clear Plastic & Vinyl Window Wax
Product attributes:
•Cleans and protects vinyl windows and other clear plastics
•Provides UV protection
•Great for colored plastics
Flagship Ultimate Quik Wax
Product attributes:
•Mist on, wipe off...
•Can be applied in direct sunlight
•Marine’s longest lasting protection from a spray wax
•No white residue!
•Contains Hydrophobic Polymer Technology
M91 Power Cut Compound
Formulation Change For 2012
Product attributes:
•Updated abrasive technology boost cutting power and efficiency
•New enriched polishing oils allow for heavy oxidation removal with low product 'flash'
•Easy, smooth buffing with low product splatter and dusting
•Low swirl finish with no scouring
Verder gaan is niet zo moeilijk, weten wanneer je moet stoppen wel...Bastard of Bling!
