Nieuwe Meguiar's producten voor 2010! Opties
#1 Gepost : dinsdag 3 november 2009 20:39:32
Meguiar's heeft op SEMA nieuwe producten laten zien.
Uiteraard eerst in de VS te verkrijgen en pas later in de rest van de wereld.
De nieuwe Meguiar's Dual Action Polisher G110/220v2
  • verbeterde "cruise control", aantal toeren wordt opgevoerd bij druk
  • makkelijker toegang voor koolstofborsteltjes
  • 1800-6800 opm
  • nieuw snoer
  • eindelijker dan een normale tas i.p.v. een idiote koffer
    Ultimate Protectant
  • Restores color and shine to faded surfaces
  • Quick drying formula produces a streak-free finish
  • Cures like a wax on nonporous surfaces
  • Use on interior & exterior plastic and vinyl surfaces
  • Unmatched protection & durability
  • Uses state of the art hybrid polymer technology
  • Protection & shine lasts weeks!
  • Innovative UV clear coat technology
  • Great on exterior trim
  • Won’t streak in rain
    Ultimate Wash & Wax
  • New category for us
  • Revolutionary formula that uses dispersed wax (cloudy) as opposed to soluble wax (clear)
  • Dispersed wax remains on paint after washing while soluble wax will wash right off
  • Leaves a deep, glossy, just-waxed shine
  • High, long lasting suds
  • Significant amount of high quality ingredients
  • Cleaning agents, carnauba wax, polymers
    Gold Class Rich leather pomp fles
  • All new pump bottle design
  • All new formula that cleans, conditions & protects
  • Unique, non-whitening chemistry does not leave behind “white” residue in
  • stitching or perforated leather
  • Contains aloe-Moisturizes leather surfaces to preserve appearance and feel
  • Non-Greasy, contains no oils
    Polishing compound & Rubbing compound, voor hand NIET machinaal
  • Removes oxidation, scratches and stains
  • Restores dull and neglected surfaces
  • Hand application only
  • Uses diminishing abrasive technology
  • Removes light scratches & hazing
  • Restores brilliance to dull surfaces
    Gold Class Carnauba PLUS, vloeibaar en pasta
  • All new look and formulation!
  • Enhanced with new chemistry & natural elements
  • More reflective finish
  • Refines the paint finish as you wax
  • Longer lasting, water resistant properties
  • Significantly easier application and removal
  • Premium carnauba wax protects and adds a deep, rich luster
  • Dibbuz
    #2 Gepost : dinsdag 3 november 2009 20:39:42
    Supreme & Natural Shine Wipes
  • Same high quality formula as spray products
  • Now with Scotchgard™ Protector
  • Premium wipe material
  • Cotton blend vs. synthetic
  • Large size - 7”x 9”
  • 25 per container
  • Packaged in new wipe container
    Supreme & Natural Shine, verbeterd en nieuwe fles
  • New bottle design
  • New graphics
  • Improved protection with Scotchgard™
  • Enhanced UV sunblock
    Quik Interior Detailer, verbeterd en nieuwe look
  • New bottle design
  • New graphics
  • Improved cleaning action
    Gold Class Rich Leather nieuwe look sprayfles
  • New bottle design
  • New graphics
    Odor Eliminator, nieuw geurtje, nieuwe look
  • New bottle design
  • New graphics
  • Same superior technology
  • Provides permanent odor removal
  • Encapsulates odors at the molecular level
  • New contemporary scent
  • Mandarin / Cedarwood
    Professional Headlight & Spot Repair Kit, zie deze niet naar Nederland komen
    Kit Contains:
  • Pneumatic Mini DA Sander - 1 ea
  • Pneumatic Mini Rotary Polisher - 1 ea
  • S3320 Unigrit 320 Grit Sanding Disc - 50 discs
  • S3500 Unigrit 500 Grit Sanding Disc - 50 discs
  • S3800 Unigrit 800 Grit Sanding Disc - 50 discs
  • S3F1000 Unigrit 1000 Grit Finishing Disc - 15 discs
  • S31500 Unigrit 1500 Grit Sanding Disc - 25 discs
  • S3F3000 Unigrit 3000 Grit Finishing Disc - 15 discs
  • S3FIS Unigrit Foam Interface - 1 ea
  • W4003 3” “Easy Buff” Knitted Wool Pad - 1 pad
  • W7204 4” Soft Buff Foam Cutting Pad - 1 pad
  • W8204 4” Soft Buff Foam Polishing Pad - 1 pad
  • W9204 4’ Soft Buff Foam Finishing Pad - 1 pad
  • S3BP 3” Professional Backing Pad and Adaptor Kit - 2 ea
  • S3HP 3” Professional Hand Pad - 1 ea
  • W63 3” Professional Rotary Backing Plate
  • T19MM Professional Masking Tape .75in - 1 ea
  • M10508 - 1 ea
  • M20508 - 1 ea
  • Meguiar’s Black Canvas Bag - 1 ea
  • VMGHSRCHT Professional Headlight and Spot Repair Chart - 1 ea
    Premium Professional Finishing System Unigrit Hand Pads
  • Long lasting one-piece urethane molded construction
  • Ergonomic palm grip design provides better control and less hand fatigue
  • Hook & Loop attachment system
  • For use with Unigrit Sanding/Finishing Discs and Meguiar’s Foam Buffing Pads
  • For application of abrasives, compounds, polishes, waxes and dressings
  • Ideal for hand application:
  • Unigrit Professional Sanding and Finishing Discs
  • Meguiar’s foam buffing pads
    Premium Professional Finishing System Soft Buff Pads
  • "Easy Buff" Knitted Wool Pad - W4003
  • New Hybrid Technology combines the flexibility of foam and the fast cut of wool
  • 100% wool, .5” knitted wool pad
  • 3” pad allows for access to isolated defects and smooth buffing
  • W7204/W8204/W9204
  • Similar foam pad technology as Soft Buff 2.0 pads
  • 4” pad size allows for access to isolated defects and smooth buffing
  • High tech Hook and Loop adhesion provides durability and is machine washable
  • Sold as 2 packs
  • For use with S3BP DA or W63 Rotary Backing Plates
  • Excellent Handling
  • Instant adhesion and good holding power
  • Resists curling and lifting to minimize bleed-through and the need for rework
  • Solvent and moisture resistant
  • Ideal for automotive detail applications
    60.1 yards (55 meters) length per roll
    nieuwe backingplates: 6" D/A, 3"D/A & Rotary en 3" Rotary
    Unigrit Sanding Discs & Finishing Discs
    “Sanding” Disc
  • Sanding = No foam backing (commonly called a “film” disc)
  • Designed to level texture or remove heavy surface defects
    “Finishing” Disc
  • Finishing = Specialized foam backing (commonly called a “foam” disc)
  • Designed to refine sanding marks & remove light to moderate surface defects
    In the image below you can clearly see the specialized foam backing on the finishing disc on the left. The disc on the right is a sanding disc of the same grit - notice the lack of a foam backing, hence the common term "film" disc.
    Sanding Disc Product Attributes:
  • Precise, uniform grit particles for a smooth and even sanding pattern
  • Ideal for removal of dirt, orange peel and severe paint defects on fresh finishes
  • Quickly levels texture
  • Micro hook / loop attachment system
    [b]Foam Finishing Disc Product Attributes:
  • Precise, uniform grit particles for a smooth and even sanding pattern that buffs out in seconds
  • Finishing = specialized foam backing
  • Quickly refines sanding marks & removes moderate surface defects
  • Soft foam backed disc for texture matching and scratch refinement
  • Always used damp (water only - no sanding lube)
    [b]Premium Professional Finishing System Unigrit Foam Interface Pads
  • Safely follows contours and works closer to most edges
  • Ideally engineered for use with Unigrit Sanding & Finishing Discs
  • Allows quick disc changes with micro hook / loop attachment system
  • nicknameless
    #3 Gepost : dinsdag 3 november 2009 21:04:55
    Volgens mij is duidelijk te merken dat 3M Meguiar's heeft overgenomen. Vooral de schuur produkten.
    dutchcardetailing
    #4 Gepost : dinsdag 3 november 2009 21:08:41
    Vooral de proff spullen zien er veelbelovend uit. Die 4" pads, en schuurvellen zijn ideaal op de dap/rotary. Kan niet wachten om ze te testen.
    #5 Gepost : dinsdag 3 november 2009 21:42:10
    3M laat inderdaad zijn sterkte even zien, maar Meg's zelf heeft ook niet stilgezeten en heeft de G220 op een groot aantal punten aangepast en geluisterd naar het commentaar. Nu alleen de prijzen nog knipoog
    #6 Gepost : dinsdag 3 november 2009 21:50:45
    Zo was het nog niet voldoende? Man wat een hoop nieuwe producten!
    Eens informeren wanneer deze te krijgen zijn!
    #7 Gepost : dinsdag 3 november 2009 21:54:27
    Die pneumatische set zal hier niet leverbaar zijn, is meer voor bedrijven. Raar dat ze die echt als nieuw product opvoeren.
    Zoveel pneumatische werkers zijn er niet (buiten bedrijven).
    #8 Gepost : dinsdag 3 november 2009 22:00:42
    on-topic:Ziet er ogenschijnlijk wel veelbelovend uit.
    Zijn er hier eigenlijk detailers aanwezig die privé of voor hun werk met "luchtpistolen" werken?
    off-topic:Alleen dat pak appelsientje een beetje té ( vaak genoeg gelezen dat er aardig wat gesnoven wordt aan potjes en blikjes ( dan is dit vragen om een slurpje )) LoL
    Jeroen
    #9 Gepost : dinsdag 3 november 2009 22:05:06
    Mmh, toch weer leuke producten die ik daar tussen zie staan!
    (alleen zal het wel aan de prijs zijn) sceptisch
    dutchcardetailing
    #10 Gepost : dinsdag 3 november 2009 22:07:10
    Ik denk dat er een grote markt is voor deze pneumatische sets in Amerika. Veel body shops etc maken hier gebruik van. Daarnaast zijn er een aantal professionele detailers die ze gebruiken
    bartr123
    #11 Gepost : dinsdag 3 november 2009 23:04:04
    Met grote schrik in mijn schoenen wacht ik de prijzen af.
    Ik vrees dat ene R. M. er weer wel bij gaat varen.
    Pneumatisch gereedschap ik vind het 3x niks. gerredschap voelt koud aan en heeft een akelig geluid als je er mee werkt.
    Opel Antara 2008
    Festool
    3M
    Peter Jansen
    #12 Gepost : dinsdag 3 november 2009 23:17:12
    Vind het anders fijn werken, dat pneumatische gereedschap.
    Groet, Peter
    jim
    #13 Gepost : dinsdag 3 november 2009 23:22:19
    Alweer 20 soorten dashbord/trim producten erbij zo blijkt Whistle
    Hopelijk ook minder lekkende flessen, want al die quick interior flesjes die ik al gekocht heb begonnen al te lekken als je ze niet recht had staan.
    Hopelijk zijn er beter dan hun voorganger, want die waren met toch te platjes.
    Verdwijnen er dan ook producten? anders word het aanbod wel enorm groot.
    Ben benieuwd.
    PT Cruiser
    #14 Gepost : woensdag 4 november 2009 8:42:53
    Als ik het lijstje begon te lezen dacht ik al dat alles vanaf nu Ultimate xxxxx ging heten. LoL
    ==> 6,5l TurboDiesel V8 <==
    D-J
    #15 Gepost : woensdag 4 november 2009 17:53:45
    Goeiedagschotel wat een lijst!
    B.K.
    #16 Gepost : woensdag 4 november 2009 18:46:35
    Inderdaad , laat maar komen.
    aron225
    #17 Gepost : woensdag 4 november 2009 19:14:30
    er zit niet echt iets bij waarvan ik zeg: JAAAA! dat MOET ik hebben..
    die sanding discs zijn wel leuk, alleen de stukjes die ik echt moet sanden, doe ik wel lekker met de hand.
    die wash&wax ben ik wel een klein beetje benieuwd naar,maar alsnog zie ik mezelf niet veel meg's spul bezitten
    #18 Gepost : woensdag 4 november 2009 21:14:37
    Schiet me wat anders te binnen: als straks op de markt komen dan kijkt een andere fabrikant ( namen mogen zelf ingevuld worden ) weer wat af, en komen er ongetwijfeld tegen een gereduceerde prijs tegenhangers knipoog blij
    Optisch vind ik de Megs er wel altijd netjes uit zien ( oog wilt ook wat ( met name voor de onervaren / beginners die de markt a la Poorboy's nog niet zo gevonden hebben )).
    Wellicht dat ik daarom de Monello set ook een grote plus geef!
    ( en ja ik weet dat het uiteraard om de inhoud gaat )
    SpeeDJ
    #19 Gepost : woensdag 4 november 2009 23:06:40
    Rang: V.I.P.
    Heeej! Rubbing Compound! Dat hebben ze van Commandant ook LoL
    #20 Gepost : woensdag 4 november 2009 23:11:21
    Dat was het eerste wat ik ook dacht hahahaha
    SpeeDJ
    #21 Gepost : woensdag 4 november 2009 23:12:40
    Rang: V.I.P.
    Ja, en dat bestaat al een eeuwigheid, dus echt vernieuwend is dit niet hehehe . Maar goed, hoop nieuwe producten, maar vooral ook nieuwe jasjes, als ik het zo zie?!
    Verder zie ik masking tape dat we al hebben van 3M (werkt toch prima, mag ik wel zeggen) en dat vast niet goedkoper gaat zijn van Meg's, en ik zie een polishing combo dat we al kennen van Wolfgang /Pinnacle. Van die merken is het een duur product, dus wie weet dat Meguiar's ons verrast?
    #22 Gepost : woensdag 4 november 2009 23:13:07
    Jup en wat 3M producten in Meg's jasje
    SpeeDJ
    #23 Gepost : woensdag 4 november 2009 23:18:04
    Rang: V.I.P.
    Purrrcies.
    rodders
    #24 Gepost : woensdag 4 november 2009 23:23:16
    ZItten weinig producten tussen die me echt kunnen interesseren. Enkel het package met de pneumatische tools lijken me wel iets. Spijtig genoeg komen deze waarschijnlijk niet naar NL/BE.
    Surfingwizzkid
    #25 Gepost : donderdag 5 november 2009 11:19:33
    Ultimate Protectant en de Gold Class Carnauba Plus hebben mijn interesse gewekt (waarschijnlijk totdat ik de prijs zie Whistle )
    Megs heeft tot nu toe niet echt een goede trim detailer gehad.
    [off-topic]Nu weet ik dat een aantal mensen hier lyrisch zijn over de PB Trim restorer, maar in de webshop zie ik ook SmartGel staan. Iemand hier ervaring mee? [/off-topic]
    #26 Gepost : donderdag 5 november 2009 11:38:53
    SmartGel is ook een prima keuze, gelijkwaardig resultaat als TR.
    rodders
    #27 Gepost : donderdag 5 november 2009 12:29:05
    Smartgel heb ik ook reeds geprobeerd en heb de indruk dat de trim restorer toch net iets langer blijft zitten.
    Maar heel veel verschil zal er niet op zitten, de producten zijn echt aan elkaar gewaagd.
    Steven010
    #28 Gepost : dinsdag 26 januari 2010 21:14:10
    Is er al een datum wanneer we deze spulletjes kunnen verwachten in de shop?
    Ben vooral benieuwd naar hoelang deze versie van de Gold Class wax mee gaat, want die "ouwe" ging niet zo heel lang mee maar had wel een hele mooie glans.
    Die wash and wax in ook wel interessant.
    Deze pagina is gegenereerd in 1,273 seconden.
