Autobrite Magifoam Opties
#1 Gepost : donderdag 21 oktober 2010 20:43:14
Onlangs binnengekomen met een bestelling uit UK:
Autobrite Magifoam
Omschrijving volgens de webshop van Autobrite:
Ultra high foam additive for a stable dense foam.
Magifoam has been formulated to be a concentrated ultra high foam additive that will produce an extremely stable dense foam when used through a Heavy Duty foam lance. With a light banana scent this product is extremely pleasant to work with and the stable foam produced will linger for up to and over 30 minutes meaning that there is no more rushing around to clean wheels, badges or door shuts like before whilst the foam is dwelling. By using magifoam as a foam prewash the risk of swirl marks and scratches when washing the car is dramatically reduced.
- Superior, Safe Cleaning Action
- Very High Foaming
- Banana Scented
- Economical to use.
- Produces a blanket of foam on vehicle
- Dwells on car surface up to 30 minutes giving you maximum penetration and cleaning
- Contains biodegradable surfactants
- LSP safe
- Leaves a great finsh!
Usage Instruction;
Magifoam has been primarily formulated to be used in a foam lance, with a dilution rate of 100:1 it is also very economical, this equates to roughly 1-2" in the bottom of a 1l bottle in a foam lance when using with a domestic pressure washer.To use simply rinces car surface first, then spray the car with a liberal layer of foam and allow to dwell for at least 10 minutes, after this time simply rinse the foam off and watch the dirt rinse away too. The longer this product dwells the deeper it penetrates into the dirt and more of the dirt will then be removed.
Voordat ik begon, had ik al vernomen dat deze foam betere "standtijd" had wanneer deze opgebracht werd op een "droge" wagen.
Dus NIET voorspoelen voor het foamen...
Men neme:
- Een smerige VW Transporter T5 T-edition
- Nilfisk HD met Autobrite Foamlans
- +/- 100ml Magifoam, aangevuld met warm water tot +/- 500ml totaal in de fles
Gelijk bij het openen van de fles dacht ik, die bananen-geur is ver te zoeken... weetniet
Ruik lichtelijk chemisch zelfs..?! sarcastisch
Afijn, geur is niet zo belangrijk, dus naar buiten met t zooitje een foamen maar!
Zoals gezegd, de wagen dus NIET voorgespoeld, om een betere werking/standtijd te verkijgen...
Na twee seconden foamen kwam er een heerlijke geur me tegemoet vliegen, BANAAN! ja
Dus wat dat betreft zit het wel goed met deze foam geek
Maar nu verder met de belangrijke zaken...
Reinigende werking:
Lijkt me niets mis mee toch?
Verder nog op de koplamp een leuk "fenomeen"...
Who needs Poorboy's Bug Squash? LoL
Hieronder een plaatje van de T5 na een dik kwartier:
Soortgelijk resultaat heb ik tot nu toe met de SSF nog niet behaald, terwijl ik daarbij ongeveer dezelfde dosering gebruik qua foam/water.
Andere factoren:
- Bus staat goed in de wax (Collinite 845 aan de zijkanten en achterkant, Zymöl Concours en Dodo SN op de neus en zijschermen)
- temperatuur was zo'n 18 graden, met een normale luchtvochtigheid.
- waxlaag werd (voor zover te beoordelen) inderdaad niet echt aangetast, beading en sheeting volop aanwezig na de foam-sessie!
Inmiddels te horen gekregen dat de batch foam waaruit deze komt, misschien niet goed geproduceert zou zijn, dus er komt nog een betere versie van Aaargh
Dus.... 2 B continued...... weg
#2 Gepost : donderdag 21 oktober 2010 20:51:05
Hé da's interessant, vooral het effect op de lijkjes devil
En voor de rokers onder ons, deze houdt het wel een sigaartje lang uit dus ...
Beetje jammer dat ik bijmekaar nog zeker een liter of 8 heb staan.
Wordt flink door foamen.
DennisD
#3 Gepost : donderdag 21 oktober 2010 20:51:06
Thx voor de review, ziet er goed uit. Was erg benieuwd hoe deze foam was na de verhalen op DW te hebben gelezen. Zodra mijn SSF op is ga ik eens shoppen voor de Magifoam. great
Mark1986
#4 Gepost : donderdag 21 oktober 2010 21:09:07
Klinkt als een goeie foam boos
Blamm
#5 Gepost : donderdag 21 oktober 2010 21:16:57
18 graden met normale luchtvochtigheid, waar woon jij ergens? LoL
Foam ziet er goed uit. Je kunt je vraagtekens zetten bij het (extreem) lang blijven hangen van het foam, het doel is ten slotte het vuil af te voeren, maar de resultaten liegen er niet om!
Dré
#6 Gepost : donderdag 21 oktober 2010 21:26:24
Mooie review Ivo! Bekende pics blij http://forum.carclean.nl...-Deel-7.aspx#post157696
Ik heb zelf nog geen review gemaakt voor Carclean.nl aangezien dat blijkt dat de eerste batch van de magifoam een niet juiste mix was.
Dit probleem is inmiddels opgelost en een 2de batch is beschikbaar die het nog beter moet doen als deze.
Aangezien de 1e batch nog niet helemaal goed was wel gepost op DW voor AB (sorry engels)
In elk geval het is echt een aanrader (ook al is deze batch nog niet 100%) de reinigins kracht is echt super! Zoals
Ivo ook al aangaf je hebt echt absoluut geen bug (wax) killer producten meer nodig ze gaan er zo vanaf. De foam is tevens wax safe!
Aanrader!
@Tim moest vragen van Mark of je interesse hebt in wat liters.....!
Is the magifoam and operation not dependent on certain factors ?
- rinse the car or not rinse just direct foam
- is the car dirty (foam sticks on dirt)
- state of the wax on the car (beading - sheeting)
Did tryed the magifoam today also some pics:
! Note the car was washed and then fully covered with Berry Blast 2weeks ago, car was not really (extreme) dirty and there was enough beading and sheeting from the Berry Blast and the 5 weeks old Addiction.
So first rinsed the car with the garden hose (on the label there is no note must be rinsed first like the SSF)
Foaming blij
Total used:
Then waiting....
Most of the foam was gone after 10mins the car was already slightly drying but it was here today 25 degrees and it was blowing very hard very hot air. (maybe also a factor)
Some befor and afters (note only rinsed off with the garden hose not with the high pressure washer!)
My thoughts,
It is not so sticky or linger then I had imagined or as read on the label or see on shots here on DW. But when I compare it with the SSF or the Citrus Pearl Autowash Shampoo that I already used to foam those two are usually already in less then 5min gone of the car (in my case) Even not compared with the weather of today here! I think the magifoam and operation are dependent on certain factors (dirt, rinse, weather).
Pros!
- The magifoam has much more cleaning ability then the SSF or the Citrus Pearl Autowash Shampoo and it is wax safe.
- More economical to use then the SSF and the Citrus Pearl Autowash Shampoo, because of the more cleaning ability.
- Smells good has a light banana odor.
It's a keeper for sure for me, if it is a good or bad batch.......... and 30minutes waiting on foam is long blij
#7 Gepost : donderdag 21 oktober 2010 21:28:35
Deze foamtest was een week of 3 geleden cool vaandaar de temperatuur en luchtvochtigheid....
Mr MvD
#8 Gepost : donderdag 21 oktober 2010 22:28:50
Interessant.
Mijn 5 liter SSF komt binnenkort aan z'n eind,
en wil dan eigenlijk iets met wat meer reinigingskracht.
Komt deze in het assortiment van Carclean.nl ?
Havanna
#9 Gepost : donderdag 21 oktober 2010 22:54:47
Mijn (pure) SSF is vandaag opgegaan, heb nu nog 2 brouwseltjes staan van wat SSF + andere ingredienten, waarmee ik 3 a 4 auto's kan doen. Tijd voor een nieuwe dus. Net voor dat ik m'n bestelling vanavond eruit wilde doen kwam ik deze tegen, en wacht dus even met het bestellen van een nieuwe gallon SSF.
Bij het zien van deze review is m'n intresse nl. erg groot voor deze Magifoam ja
Eelco
#10 Gepost : donderdag 21 oktober 2010 23:10:12
Heb je de Bilt-Hamber al eens gebruikt Patrick?
-Dries-
#11 Gepost : donderdag 21 oktober 2010 23:31:00
misschien een gekke vraag, maar hoelang blijft het op de straat liggen? Ik gebruik namelijk geen SSF meer omdat het de volgende dag, dan wel niet de dag daarna nog steeds in de goot ligt... De bilthamer is met een kwartier weg, en foamt net zo goed.
Havanna
#12 Gepost : donderdag 21 oktober 2010 23:57:15
@Eelco: ja , heb ik is een klein flesje Autofoam gekregen. Prettig werkend m.i. en redelijk gelijkend aan de SSF. Heb lopen pielen met de concentratieverhouding, want 1:100 resulteerde in een zielig beetje "motsneeuw", terwijl ik met foamen liever de categorie "sneeuwstorm" voorbij zie komen hehehe
@Dries: zolang op straat blijven liggen? Aaargh
Zoiets dergelijks nog nooit meegemaakt eigenlijk. Misschien domme vraag, maar je hebt het toch wel verdund aangemaakt?
Quincy
#13 Gepost : vrijdag 22 oktober 2010 8:14:07
Als ik zie wat er maar uit de fles is weetniet doe ik iets verkeerd...
Gebruik zelf SSF en doe daar 100 ml van in de foamgun, rest aanvullen met water en als ik klaar ben met foamen is mijn flesje voor 3/4 leeg
tee-dee-ie
#14 Gepost : vrijdag 22 oktober 2010 19:12:51
Ik gebruik zelf de SSF en het is mij opgevallen dat, bij het gebruik van de Gillmour foamgun, de foam vreemd genoeg langer op de grond aanwezig blijft dan bij het gebruik van de hogedrukspuit met foamgun. Op de één of andere manier lijkt het schuim met de Gilmour dan "steviger" te zijn dan de foam met de hogedrukspuit.
Groeten,
Erik
chost10
#15 Gepost : vrijdag 22 oktober 2010 19:57:22
Komt deze ook bij Carclean.nl in het assor ?
McShine
#16 Gepost : donderdag 27 januari 2011 9:31:46
Schijnbaar wel, hij staat nu bij nieuwe producten...weg
A.k.a Ralf
Don, Dodo Juice
#17 Gepost : donderdag 27 januari 2011 10:40:35
#18 Gepost : donderdag 27 januari 2011 10:50:53
damn, had ik toch nog ff moeten wachten met bestellen...sarcastisch
maar komt goed jippie
McShine
#19 Gepost : donderdag 27 januari 2011 10:56:23
En besteld.... Samen met de Iron-X, ben er zeer benieuwd naar!
A.k.a Ralf
Don, Dodo Juice
D-J
#20 Gepost : maandag 7 februari 2011 15:39:21
Vandaag ook gebruikt. (zie http://forum.carclean.nl...-Deel-7.aspx#post187150)
Ben er erg tevreden over. Iig was het resultaat beter dan SSF!
jim
#21 Gepost : maandag 7 februari 2011 23:44:27
Deze ga ik me ook eens aanschaffen als die echt beter is dan Carclean.nl SSF of Autobrite SSF want die laten me eigenlijk wat in de steek op gebied van werking.
popeye_65
#22 Gepost : dinsdag 8 februari 2011 23:23:45
Ik zit na te denken om zo HD autobrite set aan te schaffen incl Magifoam voor mijn Nilfisk. Nu heb ik alleen twee vragen:
1: is 115 bar genoeg om een goede dikke schuimlaag te maken?
2: ik heb een aantal keer gelezen dat mensen wax of shampoo erbij mengen. Wat is hier de reden van?
Gr, Pascal
#23 Gepost : dinsdag 8 februari 2011 23:28:20
1 115 bar is MEER. dan genoeg,
2 wax lijkt me sterk,shampoo kan wel (extra reinigende werking,of voor de geur lid...)
popeye_65
#24 Gepost : woensdag 9 februari 2011 12:29:26
Ok ik denk dat het shampoo was dan ja. Maar ik heb nog een oude paarse fles van Meguiar's staan (weet de naam even niet meer) en shampoo van poorboys. Maar Magifoam heeft al de beste reinigende werking. Dus of het daadwerkelijk nut heeft om dit toe te voegen. Geur haha de neus wilt ook wat blij
#25 Gepost : woensdag 9 februari 2011 13:10:26
Denk dat i.p.v. wax je misschien APC bedoelt?
Soms doet men dat als men de bestaande waxlaag wil strippen. Scheutje APC erbij helpt dan wel.
Danielle
#26 Gepost : woensdag 9 februari 2011 14:02:42
De Magifoam wil ik ook wel. Maar 1 liter vind ik te weinig en 5 liter te veel. Heb nog zeker 3 liter SSF.
Wie wil met me delen? Dan kun je me een pm sturen.
popeye_65
#27 Gepost : woensdag 9 februari 2011 15:23:53
Ik denk dat het APC was ja. Wax laag zal er niet opzitten. Heb deze auto nu 3 a 4 maanden en zit volgens mij geen wax laag op.
vonred
#28 Gepost : woensdag 14 december 2011 12:44:27
Ik heb nu een aantal maal de Magifoam gebruikt, maar volgens mij wordt de wax laag minder.
Zijn er meer met deze ervaring?
Ik gebruik 100ml foam en vul de fles af met warm water.(1:9)
Ik spuit de hele fles(1Liter) leeg op de auto.
Doe ik wat verkeerd?
#29 Gepost : woensdag 14 december 2011 16:07:47
sorry , ik heb voorlopig geen antwoord op bovenstaande vraag , MAAR ....(iets totaal anders maar heeft ook met foamen te maken hehehe ) :
ik heb geprobeert/getest of er ook andere flessen op de foamgun passen en kwam tot dit resultaat :
de aansluiting/schroefdraad van een "bilberry" (velgenreiniger) komt exact overeen met de originele fles
misschien wel handig , moest je originele stuk zijn of al wat ouderdom hebben of als je veeeeeeeeeeeeeeeeeeel schuim zoekt te spuiten
op bvb meerdere wagens tegelijk of een caravan/mobilhome ja
ik heb voorlopig enkel de "foam" die origineel bijgeleverd werd bij mijn spuit en ik neem volgende verhouding :
100 ml foam en 500 ml warm water erbij , ruim genoeg om bijna 2 keer rond mijn wagen te lopen (GSIII)
deze shampoo schuimt zeker niet hard maar zou wel erg effectief zijn , en dat is wat telt , niet ?
#30 Gepost : woensdag 14 december 2011 17:36:49
@Vonred,
ik doe tegenwoordig 75ml magifoam in een literfles, probeer dat eens. Ik heb niet gemerkt dat mijn waxlaag minder werd, maar ik foam ook alleen als die echt heel, heel vuil is. Ik foam gewoon de auto en als alles onder zit is het klaar voor mij. Dus ik maak niet perse die liter op.
#31 Gepost : woensdag 14 december 2011 17:43:59
+ 1 niet teveel nemen.
Magifoam is nogal krachtig t.o.v. de anderen en blijft lang hangen
De werking is afhankelijk van de kracht en de contacttijd, dus ...
Dat nog versterkt door de warmte ... en misschien onthard water weetniet
Deze pagina is gegenereerd in 0,672 seconden.
